Starter suggestions - SmokinVette.com Forums
post #1 of 7 (permalink) Old 12-05-2012, 12:44 PM Thread Starter
Arrow Starter suggestions
I'm looking for a new starter for my '77. Chevy Big Block 350 V8 engine and I'm looking for a high torque mini starter that will work. Any suggestions? I've found some models on Jegs and Summit Racing, but I'm not sure if they are compatible with my engine. Thanks.
'Nugz 77 is offline
post #2 of 7 (permalink) Old 12-06-2012, 06:09 AM
May I ask why you want to go to a "specialty" starter when an ordinary starter will work perfectly?
post #3 of 7 (permalink) Old 01-13-2013, 06:28 PM
I'll ask the same question. Why a specialty mini starter? From your post, it would appear to those who do their own work that you might not have the experience or knowledge of engines to require a mini starter. Did you know that a 350 is actually a small block?
Duane
duane4238 is offline
post #4 of 7 (permalink) Old 01-14-2013, 05:04 PM
reduction gear starters work great
but
they are not reallt needed unless you are running a real high compression ratio
post #5 of 7 (permalink) Old 01-14-2013, 05:56 PM
they are nice tho.. I have a Hi-Torque Mini on my stroker ... roller bearings, smooth ,quiet, powerful, lightweight.. good up to 15:1 compression ratios ... and it fits either smallblock or big block, small or large flywheel /flexplates as long as your block is drilled inline...also last longer
post #6 of 7 (permalink) Old 01-14-2013, 06:10 PM
C5's have them stock
post #7 of 7 (permalink) Old 01-15-2013, 03:15 AM
yep, saves about 7 lbs
Tags
350 bb v8 , starter
