Timing question - SmokinVette.com Forums
post #1 of 14 (permalink) Old 10-14-2012, 12:50 PM Thread Starter
Timing question
SBC running a 4bolt main, Comp cam ( Xtreme energy XR276HR) World Heads Sportsman II 2.100/ 1.625 72cc 23degree angle,Sidemount Hookers, Edelbrock Aluminum intake Performer, Holley 650 cfm, Accel High Performance HEI Distributor.......question is, what is the best timing to run with this set up. I'm currently set at 8 degrees advanced. Seems to run ok but everyone says I should be running at 12 or more advanced. I have a new high torque starter to be installed as it is hard starting when I run it hard for a while. If I run it below 6 degrees the headers glow. Too hot and to late on the timing right?
Cruzin_Flick is offline
post #2 of 14 (permalink) Old 10-14-2012, 01:06 PM
TimAT's Avatar
Not only is the initial timing important, but the total advance is too. AND the rate of advance. IT's all adjustable with a combination of vacuum advance cans, springs and weights.
Lots of ways to get there. Easy way is to send an email to Lars at v8fastcars@msn.com and politely request a copy of his timing paper. Follow his instructions and you get 2 things- 1, an understanding of how it works, and 2, the timing on your car set correctly.
TimAT is offline
post #3 of 14 (permalink) Old 10-14-2012, 02:44 PM
Agreed, good advice.
buster is offline
post #4 of 14 (permalink) Old 10-14-2012, 03:22 PM Thread Starter
Thank you, the email is on its way.
post #5 of 14 (permalink) Old 10-14-2012, 04:16 PM
the purpose of advance is to light the fuel/air earlier in the cycle as the rpm goes up....it takes the same amout of time to light at 5,000 rpm as it does at 1000 rpm, so you must light it off earlier to achieve proper burn. a performance chev small block usually needs 10-14 * initial adv , plus 20-22 centrifugal adv in by 2500-3000rpm , for total 34-38* .. and if you use a vacuum advance, you can add 10-12* for it at part throttle, which will give you 44* or more at light throttle, cruising speed .. ...this is based on premium fuel useage......this will vary slightly by cam /head design on any given engine .. if your pipies are glowing, you have late ignition timing or you have an exhaust restriction... I run my 383 stroker with 14* initial, 22* mechanical and 10* vac adv.. we tried various combo on the dyno, this is where it was "HAPPY"...
post #6 of 14 (permalink) Old 10-16-2012, 01:17 PM
TimAT's Avatar
THose same numbers apply to the big blocks too. I'm running a total of 36*.
TimAT is offline
post #7 of 14 (permalink) Old 10-16-2012, 09:59 PM
great minds think alike, eh?
post #8 of 14 (permalink) Old 10-17-2012, 11:09 AM
TimAT's Avatar
I don't know if it's the great minds or just the stuff that we have discovered (by trial and error) that works..
My normal trial and error:
TimAT is offline
post #9 of 14 (permalink) Old 10-17-2012, 02:23 PM
LOL!!! lots and lots of ERROR!! I think I ve invented a few new words on occasion, when things go haywire..
post #10 of 14 (permalink) Old 10-19-2012, 12:51 PM Thread Starter
Thank you all very much for the info. Received an email from Lars........Wow! He really knows the issue of timing!! Very impressive!!
