New Speedo Cable Lube - SmokinVette.com Forums
post #1 of 8 (permalink) Old 11-30-2010, 03:18 PM Thread Starter
Hello,
I purchased a speedo cable from Corvette Central
and was going to lube it before install.
Doesn't look like it will come apart though.
Are these lubricated before they're assembled?
Anyone have exp with AC Delco casings?
Are they a better way to go?
Thanks for the help.
moab302 is offline
post #2 of 8 (permalink) Old 11-30-2010, 04:16 PM Thread Starter
Ooops, I spoke too soon.
I was able to remove the core and lubed it with white grease.
moab302 is offline
post #3 of 8 (permalink) Old 11-30-2010, 04:52 PM
should do the trick.
post #4 of 8 (permalink) Old 11-30-2010, 09:11 PM
I have always used #2 "moly" chassis lube. Then the lube job is good for about 50,000 miles. To lube the cable I always pump the grease through the housing then insert the cable.
post #5 of 8 (permalink) Old 12-07-2010, 08:01 AM
Cable Replacement
What all approx. is involved with replacing the speedo cable? Mine was squeaking loudly and I had it lubed however now the squeaking has returned. Just wondering what it would entail to replace the cable all together.
rjrst13 is offline
post #6 of 8 (permalink) Old 12-07-2010, 01:09 PM
Just unscrew it from the transmission and disconnect it from the back of the speedometer. If yours is squeaking again just re-lube it. I always inject #2 grease into the housing (completely filling it) then shove the cable in.
post #7 of 8 (permalink) Old 12-07-2010, 05:03 PM
TimAT's Avatar
I've seen a few that appeared to be the cable, but actually the speedo head. I had to get the head rebuilt on my 77 when it started doing that.
TimAT is offline
post #8 of 8 (permalink) Old 12-08-2010, 05:13 AM
Okay. I'll have to try relubing it first then i'll check to see if its the speedo head. This is also a possibility because the noise is very loud from the passenger compartment. Thank you's for the advice!
rjrst13 is offline
