Gymkhana suspension - SmokinVette.com Forums
post #1 of 9 (permalink) Old 08-12-2009, 02:04 PM Thread Starter
Gymkhana suspension
How would I know if my '82 has the "Gymkhana" suspension I see listed in the 1982 Corvette specifications? I see they made 5457 cars with this suspension, but I have no idea how I would tell whether or not I have one. My '82 has a 7 leaf steel rear spring. Is that what the Gymkhana suspension is all about? A 7 leaf steel spring? Or did the Gymkhana suspension use a single leaf fiberglass spring? And is the Gymkhana suspension a stiffer suspension? My '82 is pretty rough riding, and I have often suspected my suspension is stiffer than normal. Also, I have heard the car's specifications are on a gas tank sticker. Where on the gas tank would I find this sticker? I bought this car with only 43,000 miles on it back in 1988, and I really doubt the previous owner would have removed the sticker.
I can put my car into a sideways slide and there is hardly any body roll at all. And when I jack it up ANYWHERE on the frame, both left (or right) side tires lift up off the ground at virtually the same time. It's REAL stiff. Gynkhana?
post #2 of 9 (permalink) Old 08-12-2009, 02:31 PM
not sure about suspension details but spec sticker is on top of fuel tank, dont think you can read it without removing. as for rear spring ,my 81 is the fibreglas monoleaf and it has no lean in corners at all
post #3 of 9 (permalink) Old 08-12-2009, 04:47 PM Thread Starter
I take it you have never replaced your rear spring? It's the original one? It seems that most people who have the 80-82's also have the fiberglass mono spring. As I have this mother of a 7 leaf steel rear spring, I wonder if it's a heavy duty option.
post #4 of 9 (permalink) Old 08-12-2009, 05:25 PM
dont know for sure but my 79 had steel set up came on l-82 options .i find the monoleaf quieter smoother and better in corners , itworks good on holeshots too ,no wheel hop
post #5 of 9 (permalink) Old 08-12-2009, 09:11 PM
According to Eckler's, a Gynkhana style leaf spring is a steel 7-leaf.
74VetteKid is offline
post #6 of 9 (permalink) Old 08-13-2009, 10:44 AM
When I first got my '78, I had the rear end rebuilt and went from the Standard 9 element steel rear spring to the Gymkhana 7 element spring, (ordered from Chevy): you've got a Gymkhana.
metalkid is offline
post #7 of 9 (permalink) Old 08-13-2009, 03:16 PM Thread Starter
So what does the Gymkhana spring do? Does it give the car a stiffer ride? Is it some kind of high performance option? And does the Gymkhana suspension come with a different set of front springs?
UPDATE UPDATE UPDATE. I just went outside and counted my spring leaves. And I have 9 leaves; NOT the 7 that I thought I had.
post #8 of 9 (permalink) Old 08-13-2009, 11:45 PM
While there are only 7 springs, they are stiffer than the standard 9. The stiffer suspension allows the vehicle to turn sharper and faster without the body "rolling". For performance handling (and braking), you want stiffer, stronger suspension (but your ride will be rougher). For a more comfortable ride, a more forgiving suspension set up is better, at the cost of performance obviously.
As far as stronger suspension in the front, cars with the Gymkhana suspension package also stiffer front suspension. There's really no point in upgrading one with out the other, as you will run into problems with the front and back having different roll rates.
post #9 of 9 (permalink) Old 08-16-2009, 03:50 PM
bendover's Avatar
The Gymkana is a heavy duty suspension for better handling.Will give a harsher ride also.I think it is a package deal, including stiffer front coils and thicker sway bars.I believe ,but not sure,front bar is 1 1/8 " for the Gymkana.Rick
bendover is offline
