corvette c6 z51 spark plugs - SmokinVette.com Forums
post #1 of 15 (permalink) Old 04-06-2013, 08:04 PM Thread Starter
hi i was just wondering if i could install c6 z51 spark plugs to my corvette myself? what do you guys think?
warmeck is offline
post #2 of 15 (permalink) Old 04-07-2013, 10:57 AM
Ragtop 99's Avatar
plugs on the vette are pretty easy to get at, if that is what you are asking. The fuel rail covers pop off if they are in the way.
Gone but not forgotten:
11 sec 99 Z28 Vert, RIP.
Ragtop 99 is offline
post #3 of 15 (permalink) Old 04-07-2013, 11:32 AM
lostvette's Avatar
SPAM !
lostvette is offline
post #4 of 15 (permalink) Old 04-07-2013, 08:16 PM Thread Starter
Im not spam? D: and thanks im new to the corvette.
warmeck is offline
post #5 of 15 (permalink) Old 04-07-2013, 08:52 PM
lostvette's Avatar
OK ! I Apologize ...I Run E-3'S in My C-4 a 88 & they Work Good !
post #6 of 15 (permalink) Old 04-08-2013, 05:29 AM
Smokin 2000HP Road Racer
Hardnoks1957's Avatar
THE SPARK PLUGS ARE THE SAME IN ALL VETTES as far as I know. Z51 is a suspension/performance pkg,not a Corvette model.Should be no different then any other modern car as far as plugs and wires.
Hardnoks1957 is offline
post #7 of 15 (permalink) Old 04-08-2013, 07:19 AM
do not overtighten ...you will be sorry
post #8 of 15 (permalink) Old 04-08-2013, 10:25 AM Thread Starter
how do i know when to stop tighten then? should i use a toque wrench?
warmeck is offline
post #9 of 15 (permalink) Old 04-08-2013, 10:51 AM
WSTNGAS_C6's Avatar
Standard rule of thumb is finger tight and then an extra 1/4 turn with a wrench. THATS IT! As already stated, if you over tighten them you will be sorry. Oh, and don't forget a dab of anti-seize on the threads.
For those in Central Fl that like to do your own work and wrench turning, I give you Do-it-Yourself Auto Repair!!
www.DITYAutorepair.com
"Never again will one generation of veterans abandon another"
WSTNGAS_C6 is offline
post #10 of 15 (permalink) Old 04-08-2013, 12:42 PM
Ragtop 99's Avatar
C6 Z06 plugs are not the same as used in the LS3. They're one heat range colder, IIRC. I'd guess that the LS2 and LS3 use the same plugs, but the guy at the parts counter can look up the correct plug when you buy them.
To add to Wastingas, put them in by hand, until tight. That way you can feel the threads turn and know you haven't cross threaded them. I'll sometimes put them in my sparkplug socket and turn that by hand just because it is easier to handle the socket than the plugs.
Also, pull the wires off at the plug, at the base of the wire. Tugging on the wire in the middle can cause them to break. I use a little dielectric grease on the plugs to ensure a good seal with the wire, comes in a little tube when you the plugs.
