brake dust - SmokinVette.com Forums
post #1 of 12 (permalink) Old 12-11-2012, 10:26 AM Thread Starter
brake dust
Hey you GS/ZO6 guys,how do you deal with the excessive amount of brake dust on your wheels. When I brought my GS home ,the first thing I did was pull the wheels off and clean them and wax the back spaceing thinking it would be easier to clean ,NOT!
post #2 of 12 (permalink) Old 12-12-2012, 07:46 AM
Ragtop 99's Avatar
My rims have polished lips. Coated them with POR-15.
Also I switched to lower dust (and quieter) pads.
Gone but not forgotten:
11 sec 99 Z28 Vert, RIP.
Ragtop 99 is offline
post #3 of 12 (permalink) Old 12-14-2012, 10:14 AM Thread Starter
I read on another forum that people are painting the barrels to make them smooth and easy to clean.
post #4 of 12 (permalink) Old 12-15-2012, 04:07 AM
OBXCHARTERCAPTAIN's Avatar
You cannot completely eliminate brake dust. However, you can minimize it by changing the OEM pads to Ceramic pads. I have chrome OEM wheels and thats what I did. A couple of months ago I found a product called "Auto-Sol". It is a metal polish that puts a protective coat on the wheels as it polishes them. All I do now is hose the wheels down when I wash my vert and they come absolutely clean and the water sheets off. Amazing product.....I also use it my SS exhaust tips which I polished to a amazing shine.
OBXCHARTERCAPTAIN is offline
post #5 of 12 (permalink) Old 12-15-2012, 07:11 PM
c6vette's Avatar
Good info! I'm getting ready to do a z51 brake upgrade and was pondering what pads I should use. How well do the ceramic pads perform, and are they quiet?
From what I understand, the c6 + c6 z51 calipers are the same, but the brackets are different. I'm getting ready to upgrade to c6 z51 brakes all around, and i figure if I can use the same calipers, then I'll only need to buy the c6 z51 rotors + brackets.
Thanks!
2006 Blk C6 vert w/A&A Supercharger kit w/V-3 T Trim, RTech LT's w/hi-flo cats, Corsa Extreme exhaust, built .408, cam, ported LS2 heads, twin intank pumps, & DYAD CF Clutch. New dyno #'s 726rwhp/689tq
c6vette is offline
post #6 of 12 (permalink) Old 12-16-2012, 06:23 AM
[QUOTE=c6vette;641578]Good info! I'm getting ready to do a z51 brake upgrade and was pondering what pads I should use. How well do the ceramic pads perform, and are they quiet?
I have the F55 suspension. Which is different than both the base and z 51 especially with the brakes. I didn't notice ANY difference braking with the Ceramic vs the OEM pads. Some say, if you race (road course) do not use Ceramic pads. All I was concerned with was the dust and the Ceramic pads certainly do cut it down by at least 80%. My pads squeak a little when I first put them on, even though, I used the bedding system that they talked about on the forums. The squeak is gone now. Remember, the brake dust can do damage to your wheels if left on. You are still going to have to clean them but with the ceramic pads it won't be as hard. Good Luck
post #7 of 12 (permalink) Old 12-16-2012, 08:45 AM
I've had good luck using this.
post #8 of 12 (permalink) Old 12-16-2012, 06:51 PM
c6vette's Avatar
[QUOTE=OBXCHARTERCAPTAIN;641591]
I have the F55 suspension as well. I didn't think the brakes had anything to do with the suspension, so that's another variable that I'll have to look into. I don't road race, so I'll go with the ceramic. I've been talking with the guys at TPS and I'm sure they'll get me what I need, if not, I'll check with the local dealer.
Thanks!
c6vette is offline
post #9 of 12 (permalink) Old 12-17-2012, 11:52 AM
Ragtop 99's Avatar
You're not really going to gain any stopping power with with the Z51 upgrade. The base C6 brakes are capable of locking up the wheels and will haul the car down to a stop from 80 mph just as well as bigger brakes. Better brakes allow you to do repeated stops without fade because they dissipate more heat. The Z51 upgrade is mostly cosmetic. Any gain from heat dissipation that the Z51 rotors might give you will be pissed away with ceramic pads, as they will suffer heat failure pretty quickly. That's why there is the "no road race" warning with them.
I have the bobcat ceramics. They dust less and the dust color is lighter.
post #10 of 12 (permalink) Old 12-17-2012, 08:01 PM
c6vette's Avatar
After finding out that the f55 front rotors are just a bit smaller than the z51's, I thought the same things as well with regards to stopping power. As you mentioned they're also for cosmetic reasons as well. The front isn't so bad, but man, those rear rotors look so puny lol! The prices isn't bad either, found a z51 kit (rotors & brackets) on partstaxi for 519.00. I'll be keeping my stock calipers. I'm going to have the calipers and brackets powdercoated Red.
As for the pads, Mike at TPS said that the Hawk's pad bite pretty good with low dust. What's your take?
c6vette is offline
