C6 Rear Window Adjustment - SmokinVette.com Forums
post #1 of 6 (permalink) Old 08-03-2012, 09:43 PM Thread Starter
C6CORVETTEMAN's Avatar
How Do You Adjust C6 Rear Window?
Ever since I got this 06', the rear window has been too low, coming a fraction of an inch away from the rear of the roof when I lift the hatch. It binds the trim seal when I lower the hatch, and has torn the 2nd seal I have had on the car. I recently looked at several c6's in Monterey, at Laguna Seca, and noticed some others were also low. My local auto glass shop would not get be able to adjust it unless they raised the hatch to do so. I have felt that the window alone could be raised higher at its front to solve. I just looked at a guy's 07' today, and his glass is almost in perfect alignment with the roof. HELP!
Last edited by C6CORVETTEMAN; 08-05-2012 at 06:17 PM. Reason: Post appeared as a tech tip. It's actually a tech question.
C6CORVETTEMAN is offline
post #2 of 6 (permalink) Old 08-05-2012, 07:39 AM
Ragtop 99's Avatar
The glass is loose? Pictures of the problem might help.
Gone but not forgotten:
11 sec 99 Z28 Vert, RIP.
Ragtop 99 is offline
post #3 of 6 (permalink) Old 08-05-2012, 06:24 PM Thread Starter
Need 9 more posts before I can can add a link. But, I do have a you tube video showing the problem.
It's labeled: 06' C6 low rear window.
The glass and hinge are tight. I believe some sort of glass adjustment would fix it.
I am mechanically inclined and skilled. I am just looking for some tech help. Thanx
post #4 of 6 (permalink) Old 02-22-2013, 06:18 PM Thread Starter
C6 low rear window fixed!
To adjust the rear window higher, without raising the hatch; For info, it is an adhesive glue attached window. It must be cut loose from its mounted position. new seals must be installed, and the window is then adhesively bonded to the hatch. In this case, I believe the shop, "Golden State Auto Glass," used a thicker bead of adhesive, to raise the window. It can be pulled up, while still uncured, with suction cups, to help position it. This needs to be done by an experienced glass shop. Hope this is a help to someone.
post #5 of 6 (permalink) Old 02-23-2013, 06:04 AM
Ragtop 99's Avatar
glad you got the problem solved, but it really seems like something Chevy should have fixed.
post #6 of 6 (permalink) Old 02-25-2013, 09:01 AM
There is a recall out on the rear hatch hinges.
