Proper way to disconnect battery? - SmokinVette.com Forums
post #1 of 9 (permalink) Old 08-05-2009, 07:09 AM Thread Starter
OO___OO's Avatar
What's the smartest way to disconnect the battery on a C6.
both terminals? which one first...
Just the Red?
I've never been that good with electronics..
Any advice would be appreciated, I know these Vettes can be electrically temperaMENTAL!
I'm going to be under the hood checking O2 wires, spark plugs and wires, and cleaning ....
should I even worry about unplugging the car?
OO___OO is offline
post #2 of 9 (permalink) Old 08-05-2009, 07:48 AM
I'm not a vehicle electronics expert either but I have never heard of a suggested method of removing the positive or negative terminal in some order to diconnect the battery, and I've worked on mine quite a bit without any adverse problems. But, maybe I'm missing something...
steveb601 is offline
post #3 of 9 (permalink) Old 08-05-2009, 10:27 AM
Red Magic's Avatar
I've always just removed the ground first then the positive.
Current & Past Corvettes:
2007 C6 Rag Top - Current
2003 C5 Z06 - Traded in for current
1997 C5 Coupe - SOLD
1987 C4 Coupe - SOLD
Red Magic is offline
post #4 of 9 (permalink) Old 08-05-2009, 10:31 AM
Which terminal do I disconnect first?
You ALWAYS disconnect the ground wire first, and re-connect the ground wire last. Notice how I used the term "ground" rather than "negative". Because in a positive ground system, in that case you disconnect the positive "ground" wire first.
post #5 of 9 (permalink) Old 08-05-2009, 12:03 PM Thread Starter
OO___OO's Avatar
Thanks, guys.
I knew there was a particular way, in the event I do decide to unhook the batt.
OO___OO is offline
post #6 of 9 (permalink) Old 08-05-2009, 02:32 PM
talon90's Avatar
As noted always the ground (In the Corvette this is the "-" or black) terminal first and if disconnecting both terminal also connect it last.
NCM Lifetime Member
NCM Master Ambassador
2005 Precision Red Coupe - Born on 10/04/2004 Adopted 05/26/06
Past Corvettes
1997 TR Coupe. MN6 19I. Born on 04/15/1997
1984 Coupe
And yeah, we wave.
More photos on my site. www.theredlion.us/Redlion2.htm
http://smg.photobucket.com/albums/v610/talon_90th/C6/
and here:
http://photobucket.com/albums/v610/talon_90th/Corvette/
talon90 is offline
post #7 of 9 (permalink) Old 08-06-2009, 10:38 AM
Fatcat's Avatar
and don't stick your tongue on the terminals!
Corvettes of the past:
1986 C4 Corvette - Sold
1991 C4 Corvette - Sold
1997 C5 Corvette - Sold
2005 C6 Corvette - Sold
2008 C6 Corvette - Will have till the C7 Comes out!
Fatcat is offline
post #8 of 9 (permalink) Old 11-27-2009, 09:20 AM
Shifter's Avatar
Ground is the first off and the last back on
Shifter is offline
post #9 of 9 (permalink) Old 11-27-2009, 10:22 AM
Just the Red?
Always remove the ground wire first. And connect the ground wire last.
