How often to change Auto tranny fluid? - SmokinVette.com Forums
post #1 of 14 (permalink) Old 06-07-2009, 10:32 AM Thread Starter
Eleanor's Avatar
Question How often to change Auto tranny fluid?
Curious how often you all change your auto tranny fluid? Am I ok with once a year? I put maybe 8,000 miles on the Vette each year, I wouldn't say I horse the car much. I change my engine oil every 3,000 miles, even though I know the oil can last much longer. I guess it just gives me something to do on the car on a more regular intervals!
My Eleanor: 2006 C6 6 Speed Automatic
Eleanor is offline
post #2 of 14 (permalink) Old 06-07-2009, 11:19 AM
talon90's Avatar
The recommended automatic transmission fluid change interval is 50,000 miles.
NCM Lifetime Member
NCM Master Ambassador
2005 Precision Red Coupe - Born on 10/04/2004 Adopted 05/26/06
Past Corvettes
1997 TR Coupe. MN6 19I. Born on 04/15/1997
1984 Coupe
And yeah, we wave.
More photos on my site. www.theredlion.us/Redlion2.htm
http://smg.photobucket.com/albums/v610/talon_90th/C6/
and here:
http://photobucket.com/albums/v610/talon_90th/Corvette/
talon90 is offline
post #3 of 14 (permalink) Old 06-07-2009, 11:35 AM Thread Starter
Eleanor's Avatar
Is it really that high? I'm actually very surpised. There of course is no harm in doing closer intervals correct?
Eleanor is offline
post #4 of 14 (permalink) Old 06-07-2009, 03:32 PM
Unless the car is driven under severe duty conditions, there's just no point in it.
post #5 of 14 (permalink) Old 06-07-2009, 05:07 PM
talon90's Avatar
Harm, no. The difficulty of the procedure renders it a challange for all but the most hardcore DIY'ers. The transmission cooler means that you need to have the engine running to drain the fluid and to completely change it you should use a power flush. In order to change the filter you need to drop the pan.
NCM Lifetime Member
Past Corvettes
1984 Coupe
And yeah, we wave.
and here:
talon90 is offline
post #6 of 14 (permalink) Old 06-08-2009, 06:01 AM
BUBBA's Avatar
Changing the fluid is such a PITA, why even bother with it on such a regular basis if you don't need to?
Whats Hiding in Bubba's garage?
2007 Indy 500 Pace Car - 2240 miles
2001 C5 6 Speed Corvette - 96,000 miles
2003 Dodge Ram Pickup - 54,000 miles
1984 C4 Corvette - 68,000 miles - SOLD and Missed
BUBBA is offline
post #7 of 14 (permalink) Old 11-14-2012, 10:28 PM
do you have pictures of where to drain and fill the auto tranny? thanks, frank
marine57_4 is offline
post #8 of 14 (permalink) Old 12-06-2012, 06:11 AM
HI there,
The key is driving. If you reference your owners manual on the 2006, they actually say that you shouldnt have to. This is because Dexron 6 is a semisynthetic fluid and doesnt oxidize like the older stuff does.
This being said, I recommend to have the fluid COLOR AND CONTAMINATION checked.
This means, removing the drain plug, dripping a few drops onto a white piece of paper and looking at it. All Dexron fluids will turn brown over time as the fluid ages because the dye wears out. That does NOT mean it needs changing. If I see any heavy particles in the fluid, is when I recommend changing it. Thats because the fluid suspends contaminants and these need to be removed.
To Drain and fill the 6L80 in your car, its not easy. The fill plug is in the top of the case and the actual level plug looks like the drain plug on the transmission pan.
I would suggest, if its not driven agressively, not to worry about it. If you have gone 5 years without a change, it certainly would not hurt it, but its not necessary.
Allthebest, TCM
thecorvettemechanic is offline
post #9 of 14 (permalink) Old 12-06-2012, 02:52 PM
I see you just joined, TCM.. welcome to Smokin Vette
post #10 of 14 (permalink) Old 12-06-2012, 07:58 PM
c6vette's Avatar
Good info!
2006 Blk C6 vert w/A&A Supercharger kit w/V-3 T Trim, RTech LT's w/hi-flo cats, Corsa Extreme exhaust, built .408, cam, ported LS2 heads, twin intank pumps, & DYAD CF Clutch. New dyno #'s 726rwhp/689tq
c6vette is offline
