1986 Corvette Wiring - SmokinVette.com Forums
post #1 of 2 (permalink) Old 11-29-2012, 09:30 PM Thread Starter
I have a 1986 Corvette. How do you wire in a 350 small block carb engine? Thanks for your opinions, but car is this way when I purchased. I have diagrams, but I need it explained and detailed how to wire it up and what goes where. I appreciate the positive helpful posts on this forum, and really want to get this car going a little better.
Mdjohns is offline
post #2 of 2 (permalink) Old 11-29-2012, 10:00 PM
Originally Posted by Mdjohns View Post
How do you wire in a carb engine?
Pink wire from old HEI goes to the coil for Ign ( need a non comp controlled dist with vac advance)
purple wire stays on the starter
Wires to gauge senders stay
That is all you need to make the engine actually run
But because the now deleted computer controlled several items ,you need custom wiring for the fuel pump and rad fan ;
also a switch to lockup the convertor if a auto
