Realistic Hp gains from Dyno Tune. - SmokinVette.com Forums
post #1 of 13 (permalink) Old 07-24-2012, 08:24 PM Thread Starter
VetteAholic's Avatar
Alright Gents don't give me **** for asking this
The reason I am asking is because the threads that I have searched up tell the person that it's either not worth the money on stock motor or first mod then tune, etc etc.
Well, hell the question was what are the HP GAINS!?!?! Nothing else.
I took my C4 to the Dyno other weekend, 1992, 167k miles to the motor. Current mods: CAI (Cold air intake), Factory exhaust manifolds Catless, X-pipe, Borla Stingers. 52mm BBK TB. 26LB HR injectors (+2LB HR over stock)
3 dyno pulls, my C4 made 242 RWHP and 272 RWTQ. ( I was hoping a bit more but oh well)
I have 2 shops that can perform a dyno tune and I will be getting a deal from them due to sponsoring a Corvette club I'm in.
So I'm asking "What is a realistic RWHP gain from a tune based on the mods that I listed"?
Thank you.
Vettes:
1974 Stingray, (SOLD) My first Corvette.
1992 Coupe,(SOLD, 7 optisparks later.)
2007 Coupe daily driver, (Financing!)
Mods: K&N intake, Full catless exhaust, Kooks 1 3/4. Tuned by DSMLIGHTS.
Wave to a fellow Corvette Owner
Contact me VIA Facebook: Facebook.com/VetteAholic
Check out Facebook Group "Florida Corvette Owners"
VetteAholic is offline
post #2 of 13 (permalink) Old 07-25-2012, 08:42 AM
There was certainly no gain by using the 52mm throttle body as the stock throttle body will flow all the air your stock engine can possibly consume. And you're likely running too rich because of the higher flow rate of the injectors unless you dropped your fuel pressure to compensate for them.
I would think a skilled tuner could give you a lot more power after running a few tests.
post #3 of 13 (permalink) Old 07-25-2012, 05:39 PM Thread Starter
Yeah, I was thinking about swapping out the BBK over to the stock one, I still have it.
I would have thought I was running rich, turns out the dyno test came out opposite of that, I was running a bit lean. I'm not really informed with some of those numbers that printed out. For example my A/F ratio says here: (LAMBDA) 1.234.
Vettes:
post #4 of 13 (permalink) Old 07-25-2012, 05:59 PM
just don t be too disappointed if its not big gains.. a dyno pull is just a baseline for future improvements..you can see if what you do increases power.. every dyno will give a little different result...
post #5 of 13 (permalink) Old 07-31-2012, 11:21 AM
Snowweasel's Avatar
Talking
Keep us informed on how it works out ,I'm thinking of doing the same to my Baby
Snowweasel is offline
post #6 of 13 (permalink) Old 08-05-2012, 09:49 PM
slrvette's Avatar
i agree the TB is no gain. Your better off throwing the old one back on.
The injectors are larger... If you've made no adjustments to your tune to compensate for those then you probably will be running rich.
These bolts on are hurting you.
I can't remember what the hp/tq numbers are on a 92... but I do believe your in line with what you got. Those mod's imo have no given you much gain at all.
Yeah its a 84 thats HSR EQUIPPED BABY! AND RED APPROVED
388 Roller, custom grind cam, HSR, True dual exhaust,Borla and much more
In Loving memory of my first son Brandon Harley. 5/18/09- If only I could have seen him open his eyes.
May he rest in peace, in our hearts and never forgotten
slrvette is offline
post #7 of 13 (permalink) Old 08-06-2012, 10:22 AM
I can't remember what the hp/tq numbers are on a 92... but I do believe your in line with what you got. Those mod's imo have not given you much gain at all.
I have never known of a single instance in which any of the car or truck manufacturers used carburetors or throttle bodies that were sized too small for the breathing capabilities of the engine. Same goes for injectors as the stock injectors can easily flow more than enough at the recommended pressures. In the CrossFire days it was found the stock in-tank fuel pumps couldn't maintain enough pressure after about 3000 rpm but that was corrected in the '85's and up when better constructed higher-amperage pumps were used.
post #8 of 13 (permalink) Old 08-26-2012, 08:42 AM
Theo's Avatar
I would put long tume headers on the exhaust
Theo is offline
post #9 of 13 (permalink) Old 08-26-2012, 08:44 AM
Theo's Avatar
sorry I mean long Tube Headers
I changed my diff ratio to 3.73:1 and boy oh boy....good rear torque and 1/8th mile acceleration also very good! Its a bit thirsty now though..
Theo is offline
post #10 of 13 (permalink) Old 09-03-2012, 04:39 AM Thread Starter
And I still don't see an answer to my question LOL
Long tubes are on the to do list.
Vettes:
