courtesy fuse blows - SmokinVette.com Forums
post #1 of 13 (permalink) Old 04-12-2012, 04:39 PM Thread Starter
courtesy fuse blows
New to forum so hi to all. 1990 Charcoal Metallic All Original. When I turn on the radio(Bose Gold Cass only)the 15A courtesy fuse blows after a second or 3, the interior lites go out, antenna stops, and no sound from speakers. The radio is still lit and appears to be functional. Any obvious places to start looking? No changes were made to anything, it just happened one day.
whataboutbob90 is offline
post #2 of 13 (permalink) Old 04-12-2012, 08:28 PM
Originally Posted by whataboutbob90 View Post
New to forum so hi to all. 1990 Charcoal Metallic All Original. When I turn on the radio(Bose Gold Cass only)the 15A courtesy fuse blows after a second or 3, the interior lights go out, antenna stops, and no sound from speakers. The radio is still lit and appears to be functional. Any obvious places to start looking? No changes were made to anything, it just happened one day.
First of all are you sure the fuse you are using is the correct size? And are you using good quality fuses? If so try unplugging your antenna wire and try it again.
post #3 of 13 (permalink) Old 04-13-2012, 04:21 PM Thread Starter
yes i did that, same situation. Not the antenna. But I think the interior dimmer switch had a dead spot. Any help??? TIA, Bob.
post #4 of 13 (permalink) Old 04-13-2012, 10:25 PM
Do the Bose systems use an amplifier? If so try disconnecting it.............................
post #5 of 13 (permalink) Old 04-15-2012, 05:20 AM Thread Starter
the speakers are individually amplified I believe. Is there a pre amp? Is it integral to the radio or remotely located where only trolls can get to it? Thanks for your help.
post #6 of 13 (permalink) Old 04-15-2012, 06:31 PM
About all you can do is disconnect one item at a time on that circuit until you find the culprit. Does it look like anyone has previously messed with the radio or it's wiring?
post #7 of 13 (permalink) Old 04-16-2012, 05:43 PM Thread Starter
i just got a cd cass unit and i'm gonna let 'the guy' figure it out. I'll end up doing more harm than good. I'm more mechanical than electrical. btw, why can't i find an upper dash pad replacement, I've looked for weeks?
post #8 of 13 (permalink) Old 04-18-2012, 07:56 PM
By the way, why can't I find an upper dash pad replacement, I've looked for weeks?
Have you contacted all of the major vendors? In the past I have found Eckler's and Corvette Central can't be beat when it comes to having huge inventories.
post #9 of 13 (permalink) Old 04-24-2012, 05:57 PM Thread Starter
Ecklers doesn't list for '90-'93. Central has discontinued, last time i checked(last month) sux be'in me..
post #10 of 13 (permalink) Old 04-29-2012, 06:57 AM
Theo's Avatar
Each speaker has its own amplifier at the speaker and supplied with 12vdc. Most probably one of the amps draw too much current. By disconnecting all 4 amps, just take the positive wire off, and then one by one connect and you will find the trouble maker. The other option would be the CDM unit under the passenger side dash board. I would say first go for the amps at the speakers.
Theo is offline
