1986 Corvette ignition problem - SmokinVette.com Forums
post #1 of 32 (permalink) Old 07-07-2011, 11:52 AM Thread Starter
I have a 1986 Corvette that has a miss and runs rich. In the process of elimination I have tested the coil, pickup coil is new, Cap and rotor new, MSD spark plug wirers test with in range. I hooked it up to a timing light and the spark is very erratic on every cylinder. Timing light is working correctly have tested it on another vehicle. I can not seem to figure this out!!!! Any help will be greatly appreciated.
Jim Hannon is offline
post #2 of 32 (permalink) Old 07-07-2011, 12:01 PM
Do you have a CEL on?
Vettemagnet is offline
post #3 of 32 (permalink) Old 07-07-2011, 12:19 PM Thread Starter
What is a CEL?
post #4 of 32 (permalink) Old 07-07-2011, 12:21 PM
Originally Posted by Jim Hannon View Post
What is a CEL?
Check engine light.
post #5 of 32 (permalink) Old 07-07-2011, 12:25 PM
This almost sounds like a electronic spark control issue (ESC). Check your codes and let us know.
post #6 of 32 (permalink) Old 07-07-2011, 12:30 PM Thread Starter
No codes other than the 42 when timing it. Cleared all codes now nothing after driving for 30 min or more.
post #7 of 32 (permalink) Old 07-07-2011, 12:54 PM
Code 42 is EST - electronic spark timing.
When you see 42 or 43 it's usually a knock sensor that is part of the ESC system. This is the system that advances or retards the timing.
post #8 of 32 (permalink) Old 07-07-2011, 12:58 PM
How does it drive? Did it go away?
post #9 of 32 (permalink) Old 07-07-2011, 01:17 PM Thread Starter
Only got code 42 when I unhooked the EST plug to set the Base timing, that is when I noticed the erratic spark. Seems to drive well other than running rich and rough idle.
post #10 of 32 (permalink) Old 07-07-2011, 01:29 PM
Question
It could be a worn dist. gear. What weight oil are you using?
