Smog pump eliminator question - SmokinVette.com Forums
post #1 of 3 (permalink) Old 02-22-2011, 05:52 PM Thread Starter
I was wondering if anybody could tell me if I put a smog pump eliminator set-up on my 90 C4 if the check engine light stays on because when you remove the smog pump the tube from that goes to the passenger side to that breather unit with two computer connections on it, that is why I would think the light probably will come on and stay on, also should the E.G.R. be blocked off too?
Thanks any help I would really appreciate it!
KGWilder is offline
post #2 of 3 (permalink) Old 02-22-2011, 10:27 PM
CFI-EFI's Avatar
Originally Posted by kgwilder View Post
i was wondering if anybody could tell me if i put a smog pump eliminator set-up on my 90 c4 if the check engine light stays on because when you remove the smog pump the tube from that goes to the passenger side to that breather unit with two computer connections on it, that is why i would think the light probably will come on and stay on, also should the e.g.r. Be blocked off too?
Thanks any help i would really appreciate it!
The smog pump draws negligible power. Removal to clean up under the hood is the only valid considferation. The egr is closed at wot. No gain in power by eliminating it. Only a loss in fuel mileage.
Race on!!!
Jim
CFI-EFI is offline
post #3 of 3 (permalink) Old 03-15-2011, 09:17 PM
79Rod's Avatar
mine is a 90 too.
No CES if you remove the smog pump
been there, done that
PS: no gain in power with the smog pump eliminator.
79Rod is offline
