runs fine until It warms up - SmokinVette.com Forums
post #1 of 7 (permalink) Old 08-15-2010, 08:26 PM Thread Starter
vettennn's Avatar
I've been having this problem with my lt1.. 1992, it runs fine until it gets to operating temp. Then it starts to miss and kinda buck. Had check engine codes. They were for the intake air temp sensor.I replaced that and the throttle position sensor and it still happens. It's not over heating and everything else looks normal. 93,000 miles on it. Just replaced both o2 sensors and it still happens. I'm done now and I'm bringing it to a shop on Fri. I'll let you guys know what it was when I find out. The opti spark distributer was shot.... After paying $850.00, it runs great!!!
vettennn is offline
post #2 of 7 (permalink) Old 08-15-2010, 10:08 PM
slrvette's Avatar
I moved this here for you. You should get a better response.
Did you set the TPS when you changed it?
Yeah its a 84 thats HSR EQUIPPED BABY! AND RED APPROVED
388 Roller, custom grind cam, HSR, True dual exhaust,Borla and much more
In Loving memory of my first son Brandon Harley. 5/18/09- If only I could have seen him open his eyes.
May he rest in peace, in our hearts and never forgotten
slrvette is offline
post #3 of 7 (permalink) Old 08-16-2010, 05:00 AM
Not adjustable on his car; ECM takes "key on" TPS reading and uses that as base figure
What temp?
Sounds like you have a problem when computer goes into closed loop and uses the O2 sensor
post #4 of 7 (permalink) Old 08-16-2010, 05:46 AM
I've been having this problem with my lt1.. 1992, it runs fine until it gets to operating temp. Then it starts to miss and kinda buck. Had check engine codes. They were for the intake air temp sensor.I replaced that and the throttle position sensor and it still happens. It's not over heating and everything else looks normal. 93,000 miles on it. Please help....
It could be a faulty O2 sensor.
post #5 of 7 (permalink) Old 09-01-2010, 10:13 AM
my 84 vette started doing the same the other day---runs fine then when warmed up the idle drops very low and it starts chugging. I replaced a O2 sensor a couple years ago. anyone have a comment before I take into shop? lagmak
jmaki is offline
post #6 of 7 (permalink) Old 09-01-2010, 08:01 PM
robs1988's Avatar
Same thing for you; closed loop problem. Check engine light on?
robs1988 is offline
post #7 of 7 (permalink) Old 09-02-2010, 01:18 PM
Your O2 sensor may have failed already. Or the wire on it came unplugged. I'd check it out myself before taking it to a shop.
