Mobil 1 or Amzoil, which is the best? - SmokinVette.com Forums
post #1 of 21 (permalink) Old 04-12-2012, 05:42 AM Thread Starter
Does anyone know about Amzoil or Mobil 1? Which is the best and why......... Let me rephrase my question, does anyone know anything about Amzoil, Mobil 1, or Royal Purple?
jcf3027 is offline
post #2 of 21 (permalink) Old 04-12-2012, 07:58 AM
Both are good choices.. Amsoil was the first synthetic, Mobil One has been the factory fill for Corvette for more than a decade. I use Mobil One Extended Performance in everything I own..for about 30 years.. have had several engines go near 300,000 miles with almost no oil consumption or failures ..
post #3 of 21 (permalink) Old 04-12-2012, 01:10 PM
Ragtop 99's Avatar
I'll skip the debate on quality. I've seen threads like that go on for pages with back and forth at other car sites. I use Mobil 1 as the vette's oil life meter is based upon that and I change the oil when it gets in the 20% range.
Gone but not forgotten:
11 sec 99 Z28 Vert, RIP.
Ragtop 99 is offline
post #4 of 21 (permalink) Old 04-12-2012, 02:02 PM
c6vette's Avatar
Can't go wrong either way..
2006 Blk C6 vert w/A&A Supercharger kit w/V-3 T Trim, RTech LT's w/hi-flo cats, Corsa Extreme exhaust, built .408, cam, ported LS2 heads, twin intank pumps, & DYAD CF Clutch. New dyno #'s 726rwhp/689tq
c6vette is offline
post #5 of 21 (permalink) Old 04-12-2012, 08:10 PM
Pappytinker's Avatar
I believe that is not quite correct. I believe that the oil life algorithm is based on the GM4718M spec. and not on any specific brand of lubricant. And, the GM dexos1 specification supersedes LL-A-025, 6094M and 4718M specifications
"Because of the one-pointed time awareness in which the conventional mind remains immersed, humans tend to think of everything in a sequential, word-oriented framework. This mental trap produces very short-term concepts of effectiveness and consequences, a condition of constant, unplanned response to crises." Liet-Kynes - Dune
Pappytinker is offline
post #6 of 21 (permalink) Old 04-13-2012, 07:19 AM
Don't know if using another brand of oil will void the new car warranty,but I will stick with the man. rec.
post #7 of 21 (permalink) Old 04-13-2012, 11:12 AM
Ragtop 99's Avatar
You are probably correct. While I believe they used Mobil 1 in the development of the spec (i.e. actual testing), I don't know for certain.
Mobil 1 is certified to meet the spec as are several other brands. Using Mobil 1 ensures the oil meets the spec used in the oil life monitor.
Excluding racing, I'd wager that any major brand of regular oil and filter changed every 5k miles would be sufficient to see 200k miles out of the motor. There's been a lot of improvement in the last 30 yrs.
post #8 of 21 (permalink) Old 04-13-2012, 11:17 AM
Ragtop 99's Avatar
It will not void the warranty unless the oil itself contributed to the failure. Put tranny fluid in the crank case and GM will probably be on the phone with you if the motor needed rings or an oil pump. Other than that any major brand changed at reasonable intervals will keep the warranty intact.
post #9 of 21 (permalink) Old 04-13-2012, 11:24 AM
A federal law called the Magnuson-Moss Act (1975) prevents original equipment manufacturers from putting conditions on vehicle warranties attached to any product or service identified by brand, trade or corporate name, unless the manufacturer provides that product or service free of charge. As long as that lubricant meets the spec provided by the manufacturer, they must honor the warrantee.
post #10 of 21 (permalink) Old 04-13-2012, 05:25 PM
I got a legit question. I was thinking of doin my car like yours. Mine is stock 2007 coupe. And. It spins the tires. How does your do as far as gripping the road so you can take out your opponent??!! Do you get good traction? Thanx!
Maximus68 is offline
