Keyless ignition will not turn over - SmokinVette.com Forums
post #1 of 5 (permalink) Old 01-08-2010, 06:18 PM Thread Starter
I am wondering if buying this car was a mistake. I bought a 2005 Corvette when they came out and loved it...until the warranty ran out. That's when EVERYTHING began going wrong.
The latest issue is with the 'push-button' start. When pushed, it sounds like any other car trying to turn over...only it doesn't. Does anyone know what the hell is going on and how much this will cost me at the dealer?
sgarnerfoster is offline
post #2 of 5 (permalink) Old 01-08-2010, 09:50 PM
swarga's Avatar
As a counterpoint, my 2005 has been out of warranty for 2 years. The only thing that has gone wrong during that time is a broken half shaft.
The diagnostic procedure is the same as it is on cars that start with an old-fashioned key. If the engine doesn't turn over, then the first thing to check is the battery.
swarga is offline
post #3 of 5 (permalink) Old 01-09-2010, 11:50 AM
Post
If it's turning over but not starting, then check for fuel pressure at the fuel rail and spark at the plugs.
Another way to check for fuel is to look at your plugs if they are wet then you are getting fuel. If they are dry then you have no fuel pressure,
post #4 of 5 (permalink) Old 01-09-2010, 06:36 PM
powerlabs's Avatar
Sounds like a dead battery to me? Are you on the original battery? Most of them last 2-3 years.
powerlabs is offline
post #5 of 5 (permalink) Old 01-12-2010, 06:12 AM
I'm kinda like powerlabs...... maybe you can clarify your post.
What happens when you push the button?
Engine cranks (rotates) but does not start.
Engine does NOTHING.
You hear a 'click' sound that happens every time you push button.
dbradley is offline
