Tuning at Idle - SmokinVette.com Forums
post #1 of 5 (permalink) Old 08-25-2010, 08:23 AM Thread Starter
InjectorsPlus's Avatar
Tuning at Idle
A tip about tuning at idle.
DO NOT TRUST YOUR WIDE BAND.
Wide band readings at idle are typically thrown off and can read more rich or lean depending on your cam.
The correct way to set the idle is to disconnect the IAC, Tape off or otherwise block the holes in the throttle body that go to the IAC.
Set the idle you want using the screw on the throttle body blades to get it close.
Make it leaner and leaner until you get an RPM drop. Then make it slightly richer.
Remove the tape over the holes on the throttle body and reconnect the IAC
That should get you where you need to be.
Do not look at your Wide Band as a guide.
Office:201-258-5600
Cell:201-403-3699
www.injectorsplus.com
www.facebook.com/InjectorsPlus
Custom fuel injectors for any application, marine, ATV, etc
Tuning stock and aftermarket ECUs
Fuel Pumps----Areomotive and Fuel Labs
Lines Fittings ---- Red Horse, Fragola, XRP
MARCELLA CUSTOM INTAKES
ECU-----Fast, Holley, and Motorvation
Intakes Manifolds for LSX, SBC, SBF, BBC
Carb to FI conversion kits
If it's fuel related and you don't see it, CALL, we can make it.
InjectorsPlus is offline
post #2 of 5 (permalink) Old 08-26-2010, 10:16 AM
slrvette's Avatar
Just to add and since its happening to me. DO NOT live by these WB02's you put in the car. When street turning go by your BLM's more that that wide band. Look at those just a a general guide.
They are not as accurate as one used on a dyno.
Good advice up above
Yeah its a 84 thats HSR EQUIPPED BABY! AND RED APPROVED
388 Roller, custom grind cam, HSR, True dual exhaust,Borla and much more
In Loving memory of my first son Brandon Harley. 5/18/09- If only I could have seen him open his eyes.
May he rest in peace, in our hearts and never forgotten
slrvette is offline
post #3 of 5 (permalink) Old 08-26-2010, 12:54 PM Thread Starter
Unless, of course, you don't have a stock ECU.... Then there aren't any BLMs.
Office:201-258-5600
Cell:201-403-3699
post #4 of 5 (permalink) Old 07-04-2012, 11:29 AM
Caribsailor's Avatar
90 Vette Idle problem
Before you inform me that I don’t know my whatever from a C4/C5, catch the clam shell hood. The car in fact turns out to be a C4/C5. When the engine was rebuilt the heads were shaved, modified for larger valves, and a roller cam installed. Any EM controls are no longer functioning or there including the catalytic converter. Now that I've put 2,000 miles on it the idle has gone from 1,000 rpm to 1,300 rpm. How should I lower it?
Caribsailor is offline
post #5 of 5 (permalink) Old 11-05-2012, 06:41 PM
SS39's Avatar
Your vette came from the factory with a roller cam!
SS39 is offline
